tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
cachi
Apr 18, 2013Aspirant
Hi,
I've received a ReadyNAS NV+ v1 this week by a friend as a present, it's an used unit, but it looks as a new one :) I've installed 4.1.11 and Transmission 2.77 on it.
I don't know so much about this unit, but something is going wrong with this add-on. I've modified rpc-username and rpc-password, and enabled rpc-authentication, as you can see in the following capture.
With this settings, that have been modified through Apple Terminal through SSH, there's no way to log in Web Interface :( So I decided to disable authentication...
In other hand is that it's downloading very very very slow... there's any hide setting or something weird that must be changed??
Thanks!!!!!
Thanks!!!!!
