tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
Mr_B
Apr 18, 2013Guide
Define very slow? This isn't a very fast unit.
Also, check your memory requirements, and if you got upgraded memory in your box or if it's the stock 256MB.
B!
B!
