tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
Mr_B
Apr 18, 2013Guide
There isn't any official "memory requirements" to be checked against as far as i know of, but it's a fairly well known fact that performance suffer with the original memory amount. But in my world you should still be able to get more then 400kB/s. I've been running in the area 2-3MB/s, with the rare 4MB/s showing it's ugly face every week with 2 Sundays in it. I'm not sure, but i don't think anyone squeezed more speed out of transmission then that. You can check cache size, turn off, or set encryption to optional, to try and get a weee bit more, but thats about it.
B!
B!
