tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
pugilares
May 14, 2013Aspirant
I have installation file for Transmission 2.42. It is Transmission_2.42.bin. Size of this file on disk is 21 171 KB. I have also installation file for Transmission 2.77, which is Transmission_2.77.bin. Size of this file on disk is only 1 791 KB. I didn't try to install 2.77 yet. Could you tell me if it's all right that 2.77 installation file is so much smaller that 2.42?
