tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
pugilares
May 15, 2013Aspirant
Just upgraded by first making copy of configuration files from 2.42, then uninstall of 2.42, install 2.77, copy configuration files to /c/addons-config/Transmission/ and it seems to work fine! Thank's a lot guys :-)
