tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
pugilares
Jun 03, 2013Aspirant
Does it mean that it's running, you can access web interface, you can add torrents to download/upload?
If so, there must be something with your network configuration. Are you utilising UPnP in your net?
