tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
rybackisback
Jun 29, 2013Aspirant
After updating my ReadyNAS NV+ from Transmission 2.42 to 2.8 Transmission stopped working.
When I put in a torrent file or a magnetic link and press upload nothing happens. I have refreshed the page with no luck. I have tried uninstalling and reinstalling still no luck. Now I cant get ver 2.42 to work either. Please Help. My settings.json file is as below:
"alt-speed-down": 50,
"alt-speed-enabled": false,
"alt-speed-time-begin": 540,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": false,
"alt-speed-time-end": 1020,
"alt-speed-up": 50,
"bind-address-ipv4": "0.0.0.0",
"bind-address-ipv6": "::",
"blocklist-enabled": true,
"blocklist-url": "http://list.iblocklist.com/?list=bt_level1&fileformat=p2p&archiveformat=gz",
"cache-size-mb": 2,
"dht-enabled": true,
"download-dir": "/var/local//Downloads",
"download-queue-enabled": true,
"download-queue-size": 5,
"encryption": 0,
"idle-seeding-limit": 30,
"idle-seeding-limit-enabled": false,
"incomplete-dir": "/var/local//Downloads",
"incomplete-dir-enabled": false,
"lpd-enabled": true,
"message-level": 2,
"peer-congestion-algorithm": "",
"peer-id-ttl-hours": 6,
"peer-limit-global": 200,
"peer-limit-per-torrent": 50,
"peer-port": 51413,
"peer-port-random-high": 65535,
"peer-port-random-low": 49152,
"peer-port-random-on-start": false,
"peer-socket-tos": "default",
"pex-enabled": true,
"port-forwarding-enabled": true,
"preallocation": 1,
"prefetch-enabled": 0,
"queue-stalled-enabled": true,
"queue-stalled-minutes": 30,
"ratio-limit": 0,
"ratio-limit-enabled": true,
"rename-partial-files": true,
"rpc-authentication-required": false,
"rpc-bind-address": "0.0.0.0",
"rpc-enabled": true,
"rpc-password": "{96792b9ef294d0262728648b7f397c649983b72bSTOJSxyI",
"rpc-port": 9091,
"rpc-url": "/transmission/",
"rpc-username": "",
"rpc-whitelist": "127.0.0.1,10.0.0.*,192.168.*.*",
"rpc-whitelist-enabled": true,
"scrape-paused-torrents-enabled": true,
"script-torrent-done-enabled": false,
"script-torrent-done-filename": "",
"seed-queue-enabled": false,
"seed-queue-size": 10,
"speed-limit-down": 100,
"speed-limit-down-enabled": false,
"speed-limit-up": 0,
"speed-limit-up-enabled": true,
"start-added-torrents": true,
"trash-original-torrent-files": false,
"umask": 18,
"upload-slots-per-torrent": 14,
"utp-enabled": true
"alt-speed-up": 50,
"cache-size-mb": 2,
"encryption": 0,
"message-level": 2,
"peer-port": 51413,
"preallocation": 1,
"ratio-limit": 0,
"rpc-port": 9091,
"rpc-username": "",
"umask": 18,
"utp-enabled": true
