tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
tarobun
Jun 29, 2013Tutor
Mr_B wrote: Probably a stupid question. Is it update safe? Retains settings, and loaded torrents?
Thank you for your time and effort.
B!
Yep, and yep.
