tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
tarobun
Jul 02, 2013Tutor
Did you restart the NAS after upgrading to 2.80?
Also when you say it doesn't work, what in particular is not working? Is the add-on running (ie. green light on installed add-ons page)? Or is it just the upload button?
