tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
Russell_Coight
Jul 11, 2013Aspirant
Hi guys,
I can't get the service to start for some reason. The web interface will say it has started, the light will turn green for a few seconds then back to grey.
Running Transmission 2.80 and RAIDiator 4.1.12. I've tried removing/reinstalling.
I've SSH'd into the box and ran top while trying to start the service, the transmission service will appear for a second then go away if that means anything.
Are there logs anywhere? There's nothing related in /var/log/messages
Is there anything I can do? The only other thing I can think of is to factory restore the box, something I'd rather not do.
thanks
thanks
