tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
tarobun
Jul 12, 2013Tutor
Hmmm... new version of RAIDiator... Let me try upgrading my box to see if anything breaks.
Upgraded to 4.1.12 and Transmission running no prob.... so not sure what the problem is.
The transmission binaries are in /etc/frontview/addons/bin/TRANSMISSION
You can start the transmission-daemon with the option --logfile <filename> to get it write out log messages.
I did notice that the green light in the "Installed Add-ons" section is a bit slow in updating.
good luck!
good luck!
