tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
Russell_Coight
Jul 12, 2013Aspirant
tarobun wrote: Hmmm... new version of RAIDiator... Let me try upgrading my box to see if anything breaks.
Upgraded to 4.1.12 and Transmission running no prob.... so not sure what the problem is.
Sorry I should've said that it also happened for the version before, I tried to update to see if it would fix the problem.
tarobun wrote: The transmission binaries are in /etc/frontview/addons/bin/TRANSMISSION
You can start the transmission-daemon with the option --logfile <filename> to get it write out log messages.
Sorry not sure how to do this, what is the full command I need to run?
