tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
flamesong1
Jul 14, 2013Aspirant
I am unable to start Transmission v2.80 either.
I had been having problems with v2.42 crashing (web interface and GUI dropping connection and Transmission apparently not) after my ReadyNAS Duo automatically updated to RAIDiator 4.1.12 (although, I had automatic updates deselected) - so I having tried downgrading back and forth with RAIDiator to 4.1.10 and reinstalling, uninstalling Transmission 2.42, I found this new version but cannot get it to work. After installing, I get similar results to those posted above - web interface and GUI unable to connect - at least with 2.42, they could connect and I could see active torrents for up to an hour before it crashed.
But I also have the problem that whenever I try to uninstall Transmission v2.80, I am asked for a username and password which does not match the one stored on my keychain; the default 'admin' 'password1'. I don't see any mention of a new default password.
Anyway, I have gone from a fully functioning Transmission earlier today to a dead Transmission in just about four hours. I'm particularly frustrated that downgrading back to the stone age in terms of RAIDiator and Transmission versions does nothing to help. Not happy.
