tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
mdgm-ntgr
Jul 15, 2013NETGEAR Employee Retired
/var/local/Downloads sounds like a path on the OS partition. You shouldn't download to this directory.
