tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
Russell_Coight
Jul 20, 2013Aspirant
tarobun wrote: To run from command line enter: cd /etc/frontview/addons/bin/TRANSMISSION
./transmission-daemon --logfile /var/tmp/transmission.log
To view log file:cat /var/tmp/transmission.log
Is now working :) Thanks for the help
In the log was:
Couldn't bind port 51413 on 0.0.0.0: Address already in use (Is another copy of Transmission already running?)
No version of Transmission was running, but the version that comes with the NAS was installed, so I deleted that and it worked.
One problem though, I'm unable to delete any files/folders that transmission has downlaoded, permission error. Permissions are nobody/nogroup.
Is there naything I can do?
thanks
