tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
tarobun
Jul 26, 2013Tutor
Just tested watch-dir and it works fine.
Make sure the directory exists and use
"watch-dir-enabled": true
