tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
tarobun
Jul 26, 2013Tutor
Russell Coight wrote:
One problem though, I'm unable to delete any files/folders that transmission has downloaded, permission error. Permissions are nobody/nogroup.
Is there anything I can do?
Hmmm... not sure. That's the default permissions which is recommended by the transmission team to be "world-writable" (umask=0).
Maybe try playing around with the "umask" setting in the settings.json? Might need to do a bit of reading. :)
