tarobun
Nov 24, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
Russell_Coight
Aug 02, 2013Aspirant
umask 0 fixed it :)
I had cracked the shits woth Transmission and seriosuly considered upgrading to a newer unit, hoping that would fix the issues, don't have to now :)
Donation coming your way :) Thanks for putting the time into old units like these.
