tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
tarobun
Aug 09, 2013Tutor
Updated to version 2.82 - dedicated to Russell Coight
Changes:
All Platforms
Web Client
Changes:
All Platforms
- Fix webseed crash
- Fix crash when adding UDP trackers whose host's canonical name couldn't be found
- Fix crash when sending handshakes to some peers immediately after adding a magnet link
- Fix crash when parsing incoming encrypted handshakes when the user is removing the related torrent
- Add safeguard to prevent zombie processes after running a script when a torrent finishes downloading
- Fix "bad file descriptor" error
- Queued torrents no longer show up as paused after exiting & restarting
- Don't misidentify Tixati as BitTornado?
Web Client
- Fix syntax error in index.html's meta name="viewport"
- Fix file uploading issue in Internet Explorer 11
