tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
tarobun
Aug 09, 2013Tutor
spacecrap wrote: Hi there,
I just upgraded to Transmission 2.81 and found out that I could enter the transmission web interface, but:
- all the downloads are gone from the overview (I probably have to add this manually?);
- New downloads won't start downloaden.
I have an open port, but the downloads just won't start, what can I do to fix this?
edit; strange.. it seems that the RPC port was still on 8181 in stead of 9091.. i changed this in the .json and one of the downloads works now... the other ones don't yet....
Hmmm... upgrading from 2.42(?) is a bit tricky as the settings.json file is retained and don't default to the 2.8x settings.
Maybe try renaming the settings.json file and restarting the addon so a fresh settings.json is created which you can then edit manually.
