tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
spacecrap
Aug 11, 2013Aspirant
Thanks for your reply.
I can only change the settings.json file in the 'transmission-deamon' folder... but when I change the name and start + close down transmission nothing changes.
The issue is that the folder with the new version differs from my old version.
With the new transmission the folders 'torrents' and 'resume' can be found in the root folder (\\192.168.1.105\addons-config\Transmission)
where my old torrent files can be found in the 'torrents' and 'resume' folders which are placed in the transmission-daemon folder (\\192.168.1.105\addons-config\Transmission\transmission-daemon)
I cannot copy my old files to the new folder and I don't know what I have to change to reconfigure tranmission so my old torrents can be shared again.
Is this clear and could you help me out?
