tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
tarobun
Aug 12, 2013Tutor
spacecrap wrote: I can only change the settings.json file in the 'transmission-deamon' folder... but when I change the name and start + close down transmission nothing changes.
Is there a settings.json in the /addons-config/Transmission/ folder? That's the one you should be changing. The other one is now unused.
spacecrap wrote: I cannot copy my old files to the new folder and I don't know what I have to change to reconfigure transmission so my old torrents can be shared again.
Why can't you copy the files to the new folder? Do you get an error?
There are 2 way to get your old torrents back:
1) You'll need to move all the *.torrent files in /addons-config/Transmission/transmission-daemon/torrents to /addons-config/Transmission/torrents and change your download dir to point to the old folder.
2) Edit the /etc/frontview/addons/bin/TRANSMISSION/start.sh and change TRANSMISSION_HOME=/c/addons-config/Transmission to TRANSMISSION_HOME=/c/addons-config/Transmission/transmission-daemon (and also remember to do so each time you upgrade the addon).
Option 1) is the preferable one.
