tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
spacecrap
Aug 13, 2013Aspirant
I cannot find any file that is called start.sh.... :(
maybe a clean install would do the trick?
And I'm starting to feel like a noob, but how do I enter a command line? I tried to find out on the www and ended up with putty icw. rootssh but it seems that the command line you noted has no effect.... (i know I'm missing something... but what)
