tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
tarobun
Aug 13, 2013Tutor
spacecrap wrote: I cannot find any file that is called start.sh.... :(
maybe a clean install would do the trick?
The file should be in /etc/frontview/addons/bin/TRANSMISSION if it's not that the new version has not installed correctly. What version does it say on the ReadyNAS FrontView addon services tab?
spacecrap wrote:
And I'm starting to feel like a noob, but how do I enter a command line? I tried to find out on the www and ended up with putty icw. rootssh but it seems that the command line you noted has no effect.... (i know I'm missing something... but what)
If the command was run successfully you should be able to open/edit any files in /addons-config/Transmission -> No more "access denied".
