tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
flamesong1
Aug 15, 2013Aspirant
I have been having a problem which, if I think about it, has only occurred since I upgraded to Transmission v2.8.1 and that is that I am unable to move anything out of the BitTorrent folder or rename anything in it or in subfolders. I am asked for my password which is then apparently rejected as the action is not carried out. If I copy the files to my MacBook, I have the same problem there with the only exception that my password is accepted.
The only way to do anything is to go into Frontview and reset the share's permissions but that needs doing every time because the next time I want to rename or move anything, it happens again.
I have been trying to figure this out for some time now but just realised that, as far as I know, it is only the BitTorrent folder that is affected. I don't see any mention of this issue in the release notes of 2.8.2 so I don't know if this is a known issue or just something which I am experiencing but I am wondering if Transmission is setting the file/folder permissions or maybe it is not doing something it should do.
Can anybody shed some light on this for me as it is driving me insane having to continuously reset permissions.
