tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
tarobun
Aug 16, 2013Tutor
I think they changed something in Transmission 2.8x...
What is the umask value in your settings.json file? Can you try it with "umask":0 ?
