tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
flamesong1
Aug 17, 2013Aspirant
tarobun wrote: I think they changed something in Transmission 2.8x...
What is the umask value in your settings.json file? Can you try it with "umask":0 ?
I wasn't sure if that was a reply to my post or not.
Anyway, I have just been trying to open the settings.json file and found that I could not open it or copy it the way I had been able to do in the past and even when I logged in as Admin (as opposed to my user account with Admin status), I could not open it without adjusting permissions - so I feel that something is quite wrong.
The umask value was 10 but I have changed it to 0 as you suggest and I'll wait and see what happens.
