tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
MiG_098
Aug 20, 2013Aspirant
My Duo v.1 (sparc) runs Raidiator 4.1.12 and Transmission 2.82 (fresh installation, previously deleted S-P's 2.04 version that stopped work under 4.1.12).
Works just fine but there's one problem: I couldn't stop Transmission via Duo's web-interface in order to edit settings.json file.
Short after I've unchecked it's mark and pressed Save button (green light turns off) Transmission starts itself again, it's check-box is unchecked but green light stays on.
Somehow after some manipulation I've managed to change several parameters in settings.json but now I just can't set up Transmission Remote access 'cause there's no possibility to set rpc-whitelist parameter without stopping the daemon.
Maybe there's a way to manually stop Transmission?
Update: problem solved using different browser
