tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
addam
Aug 21, 2013Aspirant
flamesong wrote:
addam wrote: I'm having some issues with a specific tracker and the readynas. I have no problems when trying to download with transmission for mac.
I get no seeders but no errors either. I alson notice that some downloads are slower to start now compared to before.
How can I find out what's wrong?
BR/addam
I have experienced exactly the same problem going back over the last two years. Whenever it happens, I either find the same torrent on a different site or use a Mac BitTorrent client.
I think I may have once reconnected to my ISP thus acquiring a new IP address and I think that also canceled the problem on that occasion but it didn't work consistently so I didn't continue with it. Anyway, I got the sense that my IP address may have been blacklisted by the tracker.
Okay, I'm happy(?) to hear that I'm not the only one with this issue.
But I have not had this problem before I upgraded to 2.82. Not sure if I can downgrade and se if it has any effect.
I really like the transmission add-on. Together with the remote-gui it is absolutely awesome.
If anyone has any ideas I can try I'm happy to listen...
Sent from my iPhone using Tapatalk - now Free
