tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
addam
Aug 28, 2013Aspirant
addam wrote:
flamesong wrote:
addam wrote: I'm having some issues with a specific tracker and the readynas. I have no problems when trying to download with transmission for mac.
I get no seeders but no errors either. I alson notice that some downloads are slower to start now compared to before.
How can I find out what's wrong?
BR/addam
I have experienced exactly the same problem going back over the last two years. Whenever it happens, I either find the same torrent on a different site or use a Mac BitTorrent client.
I think I may have once reconnected to my ISP thus acquiring a new IP address and I think that also canceled the problem on that occasion but it didn't work consistently so I didn't continue with it. Anyway, I got the sense that my IP address may have been blacklisted by the tracker.
Okay, I'm happy(?) to hear that I'm not the only one with this issue.
But I have not had this problem before I upgraded to 2.82. Not sure if I can downgrade and se if it has any effect.
I really like the transmission add-on. Together with the remote-gui it is absolutely awesome.
If anyone has any ideas I can try I'm happy to listen...
Okay,
I decided to downgrade to 2.42 since I know it has been working okay before. And now I have no problems.
I liked the 2.82 better since it was smoother to work with. Probably because it does not consume all my memory but 2.42 obviously has something right when it comes to downloading.
/Addam
