tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
emk1
Dec 09, 2013Aspirant
Hello all, I have stumbled on this thread today. I, like others here, have also been running v2.42 from Super-Fish. I opted to remove v2.42 cleanly prior to installing v2.82. Install was without incident, however it doesn't seem to be taking my settings.json config that I basically copied over from my v2.42 config.
Now I can't get transmission to start. Turned on logging switch as mentioned in a prior post. The daemon does start with the logging switch and I noticed that it picks up the settings.json from a different directory?
14:33:51.464] Saved "/root/.config/transmission-daemon/settings.json" (variant.c:1217)
instead of /c/addons-config/Transmission/settings.json
Any ideas?
UPDATE: Looks like the transmission-daemon with --logging switch uses a settings.json file in /root/.config/transmission-daemon. After a reboot of my nas, looks like v2.82 is working well.
Any ideas?
