tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
chucko58
Dec 11, 2013Aspirant
Thank you tarobun for this build! I deleted 2.42, installed 2.82, and it's working just fine - after I figured out that the web interface port changed.
