tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
geojay
Dec 22, 2013Guide
I've just installed Transmission 2.82 and I've tried to access it remotely (I've set up port forwarding on my router) but get a 403 response (Unauthorized IP Address). It works fine locally. Looking at addons-config\Transmission\settings.json I can see the line:
"rpc-whitelist": "127.0.0.1,10.0.0.*,192.168.*.*",
My router is on 192.168.1.70 so it looks like it should work. Can anyone suggest what the issue is and what I need to do to resolve it?
Thanks
Thanks
