tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
Mr_B
Dec 23, 2013Guide
Uh... I do? Weird. I don't have any PHP addon installed, and the interface button works just fine.
InTheShires wrote: Have you got a PHP package installed? You will need one.
I've had 2.82 installed on my NV+ for quite some time. I'm still on 4.1.12, but unless something broke the interface, it should work "out of the box"
NAS-t wrote: I've installed v 2.82 on my Duo (sparc) with 4.1.13.
The only thing i can think of is that your port number is wrong.
NAS-t wrote: When I click the button titled "Transmission Interface", a blank Firefox window opens. Its URL is "about:blank".
Look in: \\"YourNASHere"\addons-config\Transmission\settings.json
Your looking for "rpc-port": 8181,
8181 is MY port. You have to find out which is yours. And , if you have a favorite number, you can change it to use that. For reasons not to be explained right now, stay above 1023, and below 65535 and you'll be fine.
Once you have a number, the current, or the one you changed to, check so the number matches in the text-box on the Frontpage-page. At this point you can try it again.
Remember to stop the service before you try and save the edited file. Might even have to stop the service to get read access, for some reason. (I don't have to, but i remember having to, earlier. Not sure if it's user rights, firmware, or Transmission that changed to make it "not be needed".)
The GUI is accessed through the button on that wep-page, but honestly. Get Transmission Remote or Transmisson Remote GUI. It takes a little to figure out how to configure them, but once thats done, it's a lot more user-friendly... No, not kidding, get one of them. The second seams to be more advanced, but does something weird every now and then. For what ever reason it makes the x86 Transmission i got running on a HP WHS freeze up if i leave the app running. Get that one, and see how it works for you. (Still, we should figure out what ti takes to get the web GUI running for you, it should wok, as a backup, if nothing else.)
NAS-t wrote: How does one access the GUI, and why does the Transmission Interface button point to a blank webpage?
B!
