tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
NAS_t
Dec 23, 2013Aspirant
@Shires,
Thanks for the reply.
No, I don't have a PHP package installed, unless that's something that is part of the ReadyNAS RAIDiator software. (I don't know what a PHP is, nor what I would do with it if I had it!).
However, thanks to advice from someone with a lot of experience using Transmission on OS X, I've discovered that the Transmission Interface for v2.82 can be accessed at http://nas:9091/transmission/web/
( "nas" is the local network name of my Duo).
Apparently, port 9091 is the standard port used by Transmission on a Mac, so I tried it on the Duo, and was in like flint.
I've been able to initiate a torrent, which is downloading to the Duo as I type this. So far so good.
