tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
NAS_t
Dec 23, 2013Aspirant
@ Mr_B,
Confirmed - PHP not required. Transmission seems to be running fine right now on my Duo, and I've not installed a PHP package.
Thanks for the pointer to Transmission Remote GUI. I may check it out, but things seem to be working right now, and I'm not sure I want to add yet another layer of new software. Transmission Remote won't help me since it's a Windows program and I have a Mac.
I tried looking for \\"YourNASHere"\addons-config\Transmission\settings.json
Actually, I looked for //nas/addons-config/Transmission, since OS X uses forward-slashes instead of back-slashes. But no such folder is found.
You suggested that I put 9091 in the textbox on the web-gui page, and then push Save. Are you referring to the web page on FrontView which lists the Transmission add-on? On my Duo, there's no place to enter a port number.
Regardless, since I now know how to access the web page (at http://nas:9091), I don't need to go fiddling around with the port number.
Cheers!
Cheers!
