tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
Mr_B
Dec 23, 2013Guide
Do IT *tries to sound like Peanut, from/in "Spark of Insanity"* No really. Your just adding a magnet url handler. It pops up like any torrent client, has virtually no CPU usage, since it's not actually DOIN anything, the NAS does it all. And, when you don't use it, you just kill it off, and the NAS doesn't care.
NAS-t wrote: Thanks for the pointer to Transmission Remote GUI. I may check it out, but things seem to be working right now, and I'm not sure I want to add yet another layer of new software.
Weird. I'm guessing the share isn't added, or it's shared "as something else". Since my NAS speaks Swedish i can only guess, but i think you need to look under "shares" and see if there is anything there that seams to point at configuration stuffs for the addons.
NAS-t wrote: I tried looking for \\"YourNASHere"\addons-config\Transmission\settings.json
Actually, I looked for //nas/addons-config/Transmission, since OS X uses forward-slashes instead of back-slashes. But no such folder is found.
Wait... What? Right above the "Show Web Interface" button for the Transmission GUI, i have "Transmission RPC Port (from settings.json):" and a text box to enter info in. Thats where you should put 9091. You don't have that text box?
NAS-t wrote: You suggested that I put 9091 in the textbox on the web-gui page, and then push Save. Are you referring to the web page on FrontView which lists the Transmission add-on? On my Duo, there's no place to enter a port number.
B!
