tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
NAS_t
Dec 23, 2013Aspirant
Nope - no text box for the Transmission RPC Port.
On my Duo, the Installed Add-ons page contains a section titled "Transmission. P2P Client". In the upper-right corner is a little green dot (indicating that the add-on is active, I presume).
Below that, it says: Please disable the add-on before modifying the /addons-config/Transmission/transmission-daemon/settings.json file
Below that is a button titled "Transmission Interface", and another button "Create Torrent".
Finally, an invitation to send a donation via PayPal.
Lower-right corner has v2.82.
Perhaps you're referring to another web page?
