tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
Hairy1
Jan 06, 2014Aspirant
Firstly, my thanks to Tarobun, super-poussin and anyone else involved in keeping the ReadyNAS Transmission effort going! Up until recently I was using the last stable version I found (being 2.11) which worked fine for me.
I recently upgrade my Duo 1 to 4.1.12 and reinstalled everything, and found that Transmission 2.82 is available! Fantastic Ive given it a go and it seems to work perfectly.
Hoever there might be something Im doing wrong, when I modify the whitelist config in any way, Transmission refuses to start. Even setting whitelist to false and the service just refuses to start. Change it back, and it starts fine. In fact it appears that any change I make to settings.json causes transmission to fail on startup. Even restarting the NAS didn't help.
Any ideas on what I might be doing wrong? Im editing the config via my mac using TextEdit. Im reverting the changes I make by editing again in TextEdit. Also all changes are made when transmission is offline, of course.
Thanks
John
Thanks
John
