tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
Mr_B
Jan 10, 2014Guide
Look in settings.json for ""port-forwarding-enabled":" and make sure it says "true" as argument. Then log on to your D-link router and make sure uPnP is enabled, it's under advanced network settings. If your running a old enough Firmware, your not going to have that setting, and will need to update first, then it will be supported. After that, you should be able to ignore it, more or less. It should always just work.
dudeishere wrote: 1) I can't seem to get readynas to go through my router. I've open the port on the router (dir-655) I can confirm it is open when i point it to my laptop. I can confirm that the port is open on the readynas (netstat -a | grep 61688) but it always shows as closed on transmission. I don't see any mention on the log (using --logfile) this is what it looks like at startup:
Now that i sort of fixed your issue, or, well, hopefully at least, here comes the kicker.
If, for what ever reason, the router / firewall whatever thats in between the ReadyNAS with Transmission, and the rest of the world is restarted, Transmission doesn't seam to notice that the uPnP port forwarding no longer works, and you go deaf. From what i see, it looks like new torrents will set up new forwarding, but the old stuff remains broken. Restarting the NAS will fix the issue. I assume this is something it inherits from the Transmission code it self, and that it has nothing to do with the ReadyNAS adaptation. But i thought i should put it out there. Might simply be my Firewall that is overly anal as well. (Smoothwall SWE3.0)
B!
