tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
pepsi1
Feb 09, 2014Aspirant
Here's my feedback on the addon.
In short words: No can do..
For instance:
in start.sh: transmission-daemon is send to the foreground by the '-f ' option. But when the start-stop-daemon is called to throw the transmission-daemon to the background, the command breaks on the first fact. The correct option would be the '-g' and than the location of the 'settings.json'file. But if you set the TRANSMISSION_HOME variable correctly, you don't need that option.
Second. The environment variable "TRANSMISSION_HOME" is set incorrectly. This must be set tot the same directory as where the 'settings.json' file is.
Third: binaries does not belong into the '/etc' directory. Binaries belong (in this case) in /usr/local/bin
For instance:
