tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
tarobun
Feb 21, 2014Tutor
I find that if I don't use the '-f' (foreground) option the settings don't get saved when the addon is stopped. Probably should remove the --background option in start.sh as it is redundant in this case.
Not sure why you think TRANSMISSION_HOME is set incorrectly. It is set to '/c/addons-config/Transmission' which is where the settings.json is found.
For the binaries, I prefer to put all the files in one directory so they are easy for me to find. For me (and others I'm guessing) it doesn't really matter as we don't remote into the NAS to run the transmission commands directly. But feel free to move them to /usr/local/bin
*shrug* Works for me.
