tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
tarobun
Apr 06, 2014Tutor
raider125jeigh wrote: i'm unable to transfer or delete files coming from the Bitorrent folder... it says access denied.. i can copy files without issue..
any help will be greatly appreciated
Edit the settings.json file and set the umask to 0.
