tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
emk1
Apr 23, 2014Aspirant
kels wrote: Many thanks for this update.
Has the email alert function been removed?
I've configured my NV+ to use an external email server, installed the 'email_alert' script and changed the relevant setting to 'true' in the settings file - but it still doesn't work for me.
Am I missing something here?
Thanks
kels
@Kels
I'm still using the email alerting facility from the SuperPoussin version. I remember having issues initially when I wanted to get emails. I had it all configured but it would just never send an email. Turns out it was permissions on the script file weren't set to 'x' (execute) so it could never be called. After that it was fine. Not long ago I combined my email alert script with an unrar/unzip script to extract torrents after completion which makes my life a bit easier.
