tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
emk1
Apr 24, 2014Aspirant
Kels, you appear to have the stock email script. Compared to my own, in the second line of the script the stock SMTP_SERVER=smtp.orange.fr I changed to whatever smtp resource I am using in Frontview alert (ie: smtp.gmail.com). Not sure if this has an impact. If you can receive test emails from within the Frontview alert testing function then my experience is that Tranmission should work also.
For your reference my relevant settings are below. I think your file permissions would be fine since all users have execute. Make sure you set the script variables correctly. My script is different as mentioned previously because I chucked in an extraction command.
# pwd
/addons-config/Transmission
# ls -l|grep email
-rwxr-xr-x 1 nobody nogroup 4097 Apr 21 11:21 unrar_email.sh
# cat settings.json|grep script
"script-torrent-done-enabled": true,
"script-torrent-done-filename": "/c/addons-config/Transmission/unrar_email.sh",
I hope this helps you out.
# pwd
# ls -l|grep email
