tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
eton
Apr 29, 2014Luminary
fastfwd wrote:
eton wrote: Can anyone detect what's wrong with my settings
No closing brace. (Or did you just copy it incompletely?)
No comma after "utp-enabled": true .
Maybe missing punctuation elsewhere, too; those are just the first errors I saw.
There are online JSON validators... You might want to run your file through one to make sure it's error-free.
Thanks fastfwd
Yep I didn't copy the closing brace. I added a comma after "utp-enabled": true. And edited the post above.
And ran a validator, with no errors.
Still the same problem. Transmission starts but nothing happens, and the indicator icon in the upper right corner of the Transmisson modul panel stays grey.
How can I debug this? I've never had problems with Transmission or any other addons before.
