tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
tarobun
Apr 29, 2014Tutor
How are you with unix command line? If you are familiar then you can try the following:
If not, then there are a few things in the config you could try and remove the following settings as they don't exists anymore (see https://trac.transmissionbt.com/wiki/EditConfigFiles):
"open-file-limit": 32,
"peer-port-random-enabled": 0,
Also check the line endings in the text file, I think they should be unix style line ending (\x0a)
tarobun wrote: To run from command line enter: cd /etc/frontview/addons/bin/TRANSMISSION
./transmission-daemon --logfile /var/tmp/transmission.log
To view log file:cat /var/tmp/transmission.log
