tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
tarobun
Apr 30, 2014Tutor
Ah... oops, forgot 2 extra commands:
give it a few seconds then ctrl-c to stop the daemon then view the log file for errors.
export TRANSMISSION_HOME=/c/addons-config/Transmission
export TRANSMISSION_WEB_HOME=/etc/frontview/addons/ui/TRANSMISSION/web
cd /etc/frontview/addons/bin/TRANSMISSION
./transmission-daemon -f --logfile /var/tmp/transmission.log
