tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
eton
May 01, 2014Luminary
tarobun wrote: Ah... oops, forgot 2 extra commands:
export TRANSMISSION_HOME=/c/addons-config/Transmission
export TRANSMISSION_WEB_HOME=/etc/frontview/addons/ui/TRANSMISSION/web
cd /etc/frontview/addons/bin/TRANSMISSION
./transmission-daemon -f --logfile /var/tmp/transmission.log
give it a few seconds then ctrl-c to stop the daemon then view the log file for errors.
Thanks
Now it looks like this:
# cat /var/tmp/transmission.log
[14:00:43.286] Transmission 2.82 (14160) started (session.c:738)
[14:00:43.287] RPC Server Adding address to whitelist: 127.0.0.1 (rpc-server.c:828)
[14:00:43.287] RPC Server Adding address to whitelist: 10.0.0.* (rpc-server.c:828)
[14:00:43.288] RPC Server Adding address to whitelist: 192.168.*.* (rpc-server.c:828)
[14:00:43.288] RPC Server Serving RPC and Web requests on port 127.0.0.1:8181/transmission/ (rpc-server.c:1035)
[14:00:43.288] RPC Server Whitelist enabled (rpc-server.c:1039)
[14:00:43.288] RPC Server Password required (rpc-server.c:1042)
[14:00:43.288] UDP Failed to set receive buffer: requested 4194304, got 1048576 (tr-udp.c:78)
[14:00:43.288] UDP Please add the line "net.core.rmem_max = 4194304" to /etc/sysctl.conf (tr-udp.c:83)
[14:00:43.288] UDP Failed to set send buffer: requested 1048576, got 524288 (tr-udp.c:89)
[14:00:43.288] UDP Please add the line "net.core.wmem_max = 1048576" to /etc/sysctl.conf (tr-udp.c:94)
[14:00:43.288] DHT Reusing old id (tr-dht.c:306)
[14:00:43.288] DHT Bootstrapping from 114 IPv4 nodes (tr-dht.c:154)
[14:00:43.288] Using settings from "/c/addons-config/Transmission" (daemon.c:526)
[14:00:43.288] Saved "/c/addons-config/Transmission/settings.json" (variant.c:1217)
[14:00:43.288] transmission-daemon requiring authentication (daemon.c:546)
[14:00:43.289] Watching "/c/media/BitTorrent/sources/" for new .torrent files (daemon.c:564)
[14:00:43.289] Using readdir to watch directory "/c/media/BitTorrent/sources/" (watch.c:163)
[14:00:43.289] Port Forwarding (NAT-PMP) initnatpmp succeeded (0) (natpmp.c:73)
[14:00:43.289] Port Forwarding (NAT-PMP) sendpublicaddressrequest succeeded (2) (natpmp.c:73)
[14:00:48.314] Port Forwarding Starting (port-forwarding.c:95)
[14:00:48.535] Saved "/c/addons-config/Transmission/settings.json" (variant.c:1217)
[14:00:48.535] DHT Not saving nodes, DHT not ready (tr-dht.c:358)
[14:00:48.535] Port Forwarding Stopped (port-forwarding.c:183)
