tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
eton
May 02, 2014Luminary
tarobun wrote: Looks fine.... so what's the problem you're seeing?
Hmm, strange.
The problem is that Transmission doesn't start. And I can't access the web gui. But after I executed your commands Transmission read the settings and encrypted my password. So something has changed. But it still don't work.
It might be better to start all over. How do I get rid of Transmission completely? Will it be enough to remove the add-on from Frontview and then the rest that is left of these:
# find / \( -path '/c' -o -path '/USB' \) -prune -or -iname '*transmission*' -exec ls -ld {} \;
-rw-r--r-- 1 admin admin 206 Aug 10 2013 /etc/frontview/apache/addons/TRANSMISSION.conf
drwxr-xr-x 4 admin admin 16384 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION
-rw-r--r-- 1 admin admin 437 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION/language/en-us/TRANSMISSION.str
drwxr-xr-x 3 admin admin 16384 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION/web/style/transmission
-rw-r--r-- 1 admin admin 43146 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION/web/javascript/transmission.js
-rw-r--r-- 1 admin admin 1334 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION/TRANSMISSION.html
-rw-r--r-- 1 admin admin 8135 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION/TRANSMISSION.js
-rw-r--r-- 1 admin admin 488 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION/TRANSMISSION.xml
-rwxr-xr-x 1 admin admin 2743 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION/TRANSMISSION_HANDLER.pl
drwxr-xr-x 2 admin admin 16384 Oct 28 2012 /etc/frontview/addons/bin/TRANSMISSION
-rwxr-xr-x 1 admin admin 588300 Aug 10 2013 /etc/frontview/addons/bin/TRANSMISSION/transmission-daemon
-rwxr-xr-x 1 admin admin 615028 Aug 10 2013 /etc/frontview/addons/bin/TRANSMISSION/transmission-remote
-rwxr-xr-x 1 admin admin 580228 Aug 10 2013 /etc/frontview/addons/bin/TRANSMISSION/transmission-create
-rwxr-xr-x 1 admin admin 580128 Aug 10 2013 /etc/frontview/addons/bin/TRANSMISSION/transmission-edit
-rwxr-xr-x 1 admin admin 580168 Aug 10 2013 /etc/frontview/addons/bin/TRANSMISSION/transmission-show
-rwxr-xr-x 1 admin admin 580016 Aug 10 2013 /etc/frontview/addons/bin/TRANSMISSION/transmission-cli
-rw-r--r-- 1 admin admin 825 Apr 29 01:11 /etc/frontview/addons/TRANSMISSION.remove
drwxr-xr-x 5 root root 16384 Apr 29 16:06 /root/.config/transmission-daemon
-rwxr-xr-x 1 root root 7593660 Oct 31 2011 /usr/local/bin/transmission-cli
-rwxr-xr-x 1 root root 7808113 Oct 31 2011 /usr/local/bin/transmission-create
-rw-r--r-- 1 root root 6095 Jan 14 2009 /usr/local/man/man1/transmission-remote.1
-rw-r--r-- 1 root root 2964 Jan 14 2009 /usr/local/man/man1/transmission-daemon.1
-rw-r--r-- 1 root root 3838 Jan 14 2009 /usr/local/man/man1/transmissioncli.1
-rw-rw-rw- 1 root root 5 Apr 29 16:12 /var/run/TRANSMISSION.pid
-rw-r--r-- 1 root root 8644 May 1 14:00 /var/tmp/transmission.logOr do I have to tinker with some other files?
And what is /root/.config/ ?
